Gearbox oil change
DrewCole
Spannering the Cupra
Oct 19, 2015
695
Braintree, Essex
In the front of the service book it'll have a production sticker with a three letter code either FZQ or FML.
The FZQ box can be modded with a shim, the FML, which I have, can't.
Which is why I have a new shim and cap at home, which I ordered by mistake!
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
523
Swindon
Cheers Fella
I will check when i get back tonight, "common lucky letters FZQ" :funk:
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
523
Swindon
Car on a level surface, pour in oil until it starts to dribble out of the fill/level hole. Ideally use a funnel and tube from above the car (not my idea, but a good one). Capacity is apparently 2.6 litres.
The type of oil required depends on your gearbox code, unless you do a complete drain and refill. Two different types of oil have been used by the manufacturer, and they warn very specifically against mixing them: -
"There is a new mineral gear oil API GL4 SAE 75W (Hypoid) in accordance with TL 726 /Y. This type of oil can only be used in gearboxes where it is specified and must never be used in gearboxes that incorporate the previous oil API GL4 SAE 75W90 (Synthetic, high performance)"
"Due to the incompatibility between these types of oils, they must never be mixed as they change the properties of the lubricant."
A while ago the following list (for 6-speed boxes) was posted:
Gearbox code and oil type -
DRP / FMP / FHA / FHT / FEK / FEL / FGT / FGV / FZM / FZP / FMQ / EFF / ERF / FMH
Gear synthetic oil API GL4 SAE 75W in accordance with standard TL 521 71 (Spare no. G 052 171 A2)
DRV / EFY / EUK
Gear oil API GL4 SAE 75W 90 in accordance with standard TL 521 57 (high performance synthetic oil)
Some five-speed boxes have the following original filling
EBD, EBF, EBJ, EBM, EBS, EGW
Oil for pinions API GL4 SAE 75W90 (Synthetic, high performance)
EGR, EGS, EGV, FBK
Oil API GL4 SAE 75W (Hypoid)
Note that these oils have practically identical specifications, the same API numbers and TL standards. The only difference appears to be that the synthetic (older spec) oil is multigrade and the newer mineral oil is single-grade 75W.
It would be useful to get a more complete list, but I expect only a dealer can get hold of the information easily. In addition it would be good to know just how thorough you have to be to flush out the old oil if you have to refill with an incompatible type: will the puddles left in the corners and webs of the gearbox casting cause a problem?
Any idea what type of oil should be used for a FZQ gearbox??
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
523
Swindon
Also dont think i have an allen key that big, would this do the trick?
http://www.amazon.co.uk/Cars-Draper-38323-Drain-Plug-17mm/dp/B0001K9U28
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,329
Yeh but it must have the hole in the middle, some don't have it, just get that one of ebay
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
523
Swindon
Just need the above, oil tray, oil, some brute strength lol
Don't worry got plenty of brute strength and colorful language ready for the job :rofl:
Will be ordering the oil from the stealer in a minute. Do you know what torque settings i need to do the bolts back up to?
