The flexi joint was a total waste of time. I ended up buying a whole new exhaust. Unfortunately this did not fix the
problem. The car still makes the puffing noise when i tap the accelerator, whistling under fast acceleration, and feeling majorly under powered under 2k rpm. I have the engine management light on, which my VAG says is down to the lambda sensor.
I took the car to a mechanic about the air leak
problem, he said that these engines make bit of a puffing noise anyway, and that he didn't think it was an air leak as it would affect the engine through the whole rev range (Which it kind of does?!), he said i should replace the lambda sensor as it may be causing the engine to go in to limp mode, potentially causing the symptoms that i described. So i splashed out on the new sensor, which i fitted today, but frustratingly the EML came straight back on after clearing the codes, and the same symptoms persist.
Which now has me thinking that the lambda sensor was working fine all along, and was doing it's job in telling me that something is a miss in the air/fuel ratio.
I have now spent more on this car then what i paid for it (I paid £550), and am now incredibly frustrated and pee'd off with it.
Anyone have a clue as to what the
problem is? I tried spaying some easy start around the back of the engine in the hope that it would expose a leak, but i didn't notice any difference to the idle speed.
Any
help would be greatly appreciated!
