JohnHogan6
Leeds
First time doing this sort of stuff on my own, replaced spark plugs few weeks ago, now purchased oil, oil filter, brake discs, brake pads so going to give it a go doing these. Pretty simple jobs but without moving anything or removing anything (or going under the car) i can't see the oil filter.
Can someone locate the oil filter on the engine
literally no videos/posts anywhere they're all for the earlier models where the oil filter is in front of your face as son as you lift the bonnet
thanks in advance
thanks in advance
Look near the alternator.
Hum, yes it does hide a bit!
Broadly speaking, halfway along the engine block and halfway down, I've always approached it from above, access is a bit tight, but you should be able to get a socket on the end of that filter okay - though remove the socket once the filter has been slackened off before you run out of space.
Found it, going to attempt it tomorrow, supposedly a bit of sunshine here in Yorkshire!
Well, how did it go?
Went all well in fairness, was a struggle first getting the oil pump off as i don't think it had been swapped in a few years and the space between pump and radiator was awkward as i only had stupid size extensions for my ratchet and socket
Overall, oil all changed and new oil pump on. Brake discs and pads changed
Running smoothly again :)
I removed mine from under the car, found it easier.
I attempted that but with the awkward length extension i had for my ratchet i had a bit more space from above and easier to put more pressure on it as it was quite tight
I know it’s done the preferred thing to revive a thread this old, but I’m struggling to be sure which is the correct oil filter for my Ibiza.
It’s a 2010 1.4 petrol 16v Sport, engine BXW. Bought Jan 2025 and overdue an oil change.
It took me a while to find it (just like the OP), and I’ve tried to take a photo of the one on it to get a code number / description but have failed so far as the relevant bit is facing away from where I can access with a camera.
My confusion comes from how-to guides which are allegedly for my engine, but some show the cylinder type I’m used to (also have a Skoda, and grew up with DIY maintenance), but others have the paper filter only being replaced in existing housing.
And then to baffle me further, at least one pictured has a large hex nut fitting on the end of it. I’m used to sticking a bike chain round it and yanking!
Even putting the VIN into the usual parts places has brought up conflicting results.
Any suggestions re how to confirm the correct bit gratefully received.
A Mann W712/52 is what I used to fit to my older daughter's 2009 Ibiza 1.4 with the BXW engine, and is still what ECP comes up with for that engine, it does tend to have a large hex pattern on the end of it, I've forgotten the hex size but you'll find that out when you buy the filter.
Reactions: MijIsTired
