Hello. I want to know if the odbeleven can activated Sport menú hmi in the infortainment.
Thanks!
Has anyone tried doing any of these? I seen a youtube vid of a cupra with hazard lights on and the rear lights were blinking with indicator lights looked quite good. Still waiting on mine arriving to try out and not sure which 1 it will be either.
Flashing LED DRL dissipated
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Leuchte2SL VLB10
4 - Sub - Lichtfunktion CD 2
5 - Change value Blinken links aktiv (Beide phasen)
6 - Select - Leuchte2SL VLB10
7 - Sub - Dimmwert GH 2
8 - Change value to 36
9 - Select Leuchte2SL VLB10
10 - Sub - Dimming direction GH 2
11 - Change value to Minimize
12 - Select - Leuchte3SL VRB21
13 - Sub - Lichtfunktion G 3
14 - Change value Blinken links aktiv (Beide phasen)
15 - Select - Leuchte3SL VRB21
16 - Sub - Dimmwert GH 3
17 - Change value to 36
18 - Select - Leuchte3SL VRB21
19 - Sub - Dimming direction GH 3
20 - Change value to Minimize
Flashing DRL Simultaneous with bi-xenon headlights Basic
2 - Adaptation
3 - Select - Leuchte4TFL LB4
4 - Sub - Lichtfunktion C4
5 - Change value to Not active
6 - Select - Lichtfunktion C 5
7 - Change value to Not active
Flashing lights DRL with LED simultaneous
2 - Adaptation
4 - Sub - Lichtfunktion G 2
5 - Change value Blinken links Dunkphase
8 - Change to the desired value
9 - Select - Leuchte2SL VLB10
14 - Change value Blinken links Dunkphase
17 - Change the desired value
A slightly sideways question, but is there anything against leaving the gizmo permanently in its slot under the steering wheel, or should you (as I have done until now) only slot it in when you need it?
I've heard stories of dongles rust welding themself on by the pins due to condensation, but I think its pretty rare
2 - Adaptation
2 - Adaptation
2 - Adaptation
This is the YouTube video it's at the end when the lights flash.
https://youtu.be/VyRJAmczANI
I think they would look good with the indicator bulbs taken out?
Like a Christmas tree but Christmas are close if see this on the road i would think that there si something wrong with the wires
Sent from my Nexus 6P using Tapatalk
:lol: yeah there is far too much goin on on that car. But if it's possible to get rear led either side to blink as one and remove indicator bulbs so rear light acts as indicator it would look good.
Obv not as good but would look similar to new rear lights coming on facelift
Does anyone know if this gizmo also has the function to adjust the LED headlights up a touch, as there self leveling it would be good if this could tip them up a touch.
Is is possible, please, to disable the yellow light which comes on when not in Normal mode? Like many people, I usually drive in Sport and would prefer not seeing this particularly "warning".
Module 09
Long coding
Byte 15
Enable Bit 7
(My first post :funk:)
Ordered one of these on the 3rd November. Still not received it yet! How long has everyone waited for it to be delivered?
It took a while for mine to arrive, I think 10 working days is probably a good estimate but it was a lot longer than your average amazon purchase would take.
Sent from my XT1572 using Tapatalk
A week or a bit longer for mine as well.
Sent from my SM-G900F using Tapatalk
Excuse my level of naivety with all this but a few questions I have from this:
A)is it as easy to turn off as it is to turn on? My car is a lease if I were to do stuff to it I'd want to undo it after
B) can someone explain the "one click mirror folding" is that for cars that aren't mk3 or does it make the mk3 folding mirrors automatic when locking?
C) people have mentioned park pilot, that can be turned on despite not having the pack it's a part of? I have the standard beep beep reversing sensors but park pilot would be cool as well
D) did anyone ever answer the headlight dip question? The front dip does seem low and if that could be changed would be great
Thank you
a) yes, you just repeat the process (with the required credits). you dont need to worry about remembering what you have done either as they are listed in your car history in the app
b) thats my understanding
don't know about c&d, I always had Park pilot
Thanks, do you literally just need an android device with wifi/Bluetooth? I'm an iPhone man so would buy an android on the cheap and use it without a sim if possible
