Set time
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,276
Belfast N Ireland
Is the clock in the instrument binicle towards the Lower right hand side? If so then there should be two small buttons close by the clock. One above the other in an oblong recess. Push and hold the top lme to alter the hours and then the lower one to alter the minutes.
guncux_1
You can see where it is located,in the right corner. I tried all the button,but nothing happens.
guncux_1
How can i show you the photo? I cant post it here.
Pimped up vario
Cordy Cruizer
Nov 20, 2009
1,276
Belfast N Ireland
The first image is different from mine, showing a aircon control panel in the centre consol with a clock in the top right. I'm not familiar with the procedure for setting the time on this type. Sorry.
Jul 8, 2020
Is the clock in the instrument binicle towards the Lower right hand side? If so then there should be two small buttons of fortnite merch close by the clock. One above the other in an oblong recess. Push here and hold the top lme to alter the hours and then the lower one to alter the minutes.
it is located in right side. do check it!
