May 18, 2026
Hi there I need help with clutch kit for Seat EXEO st (3r5)
1.8 tsi 120hp/88kw
(09/2010 to 05/2013) manual 6 gears
Vin VSS ZZZ 3RZ BRO 100 09
Car is from Switzerland
Can someone help please
1.8 tsi 120hp/88kw
Hi, I looked it up in parts catalog.
For some models, it is shown as a set, but I couldn't see any listed for your VIN.
So I gathered all the coupling part numbers, thinking it may prove useful for you.
Here's the list, with number of required units in parentheses.
Also check your private message box; I'm sending you an illustration of those parts with numbers from 1 to 22, it may help identifying the parts required.
Hope it helps & cheers,
Serdar
1 - 06H141031 - Clutch plate 228MM (1)
2 - 06H141117 - Clutch pressure plate 228MM (1)
3 - N91065401 - Socket head bolt with inner multipoint head M8x14 (6)
4 - 01E141165D - Release bearing (1)
5 - 01X141719B - Clutch operating lever (1)
6 - 012141741 - Retaining spring (1)
7 - 012141751C - Intermediate piece (1)
8 - 012141777D - Ball stud (1)
9 - 01X141180 - Guide sleeve (1)
10 - N91029801 - O-ring 60,82x2,62 (1)
10A- 012311113B - Radial shaft seal (1)
11 - N90366303 - Cylinder screw, self-locking M8x22 (3)
22 - G000100 - Grease for clutch plate splines 80G
1.8 tsi 120hp/88kw
By the way, the 12th digit of your VIN is a zero, not a letter O.
The letter O is not used in VINs, to prevent confusion with zeros.
I thought you might need to know this, it is important when looking for parts online or dealing with parts resellers etc or you might end up without a result and waste your time.
