I'm just picking up a 62 plate FR and it has a sagging sound proofing, are seat charging for the fix out of warranty? If so I will do it my self,
Hi did there did you get yours replaced under warranty ? I'm picking my 62 plate up today was going to check it all before I sign on the dotted line and also could you tell me what bits are going Moldy is it the bit under the bonnet ? Or at the bulk head right at the scuttle bored cheers in advance
I didn't even bother asking as Seat by the sound of things from my local dealer are not wanting to do anything under good will etc,
Mine was the felt under the actual bonnet, it was sagging that much as it was so wet that that engine cover has a scuff mark on it and the oil filler was full of water which froze in winter!
I have now used the guide on here to fit the rubber seals under the black trim on top of the bonnet, and I have changed the under bonnet felt as well (not cheap, I'll check the receipts later but I think it was about £60 or so on trade! I did run without it for a while but it was annoying my OCD that it wasn't there)
All seems ok now, I wash the car atleast once a week normally and so far no water in the engine cover etc
Brilliant cheers for the advice appreciated
Thanks to this post! I had pot 4 keep filling up rapidly with water due to this leak. Fixed now though and hasn't done it since. Was loads worse not having the bonnet insulation!
