The
sticker is on the module as 99% of men don't read instructions and simply turn the box onto maximum and then wonder why they have seen an engine light. This usually results in us being slated on social media hence why we've added the
stickers asking customers to contact us before making any adjustments to the system
We can then explain the correct procedure and if you then decide to ignore our advice and subsequently see an engine light or experience issues, it's gives us a little recourse.
No disrespect to yourself but I'm a bloke and I never read anything but we're hoping that customers will see the
stickers and contact us, so thank you
The module itself needs power, so adjustments must be made with the ignition in the first position or with the engine running.
The box will flash the LED Lights 99% of the time - this means the box is in lock down mode and can’t be adjusted but the flashing lights indicate the Program and fine adjustment that has been selected. Once the box is unlocked by holding the plus and minus buttons down the LED lights will then go solid, this means you can adjust the system.
After several seconds of inactivity on the keypad the system will lock automatically. If in doubt at any time please read the instructions provided with the kit or get in touch.
There are 3 files on the box and 99% of the time the end result is the same overall power, the difference is how the power is delivered. Our advice is to try all 3 programmes/files/maps on zero first and you should then feel subtle differences between the 3 files.
Using the + button adds a touch more power, so from zero we would then suggest moving to +1 and then again comparing the differences.
Why haven't we mentioned +2 and +3, most files are optimised on the zero setting, but due to the differences found in sensor tolerances some cars respond better on +1. Anything higher may result in an engine management light, but there again may not. It is purely down to sensor tolerances, and in some cases fuel quality and ambient air temps can effect things.
Whatever you do please ignore anything you may of read online regarding the "best setting", intact even if you have 2 identical cars in the household please treat each vehicle as a unique item and don't simply assume that the setting you're using in one car, is the best for the other
All we want is for customers to be able to enjoy our product, but to also realise that their car is as unique as them, and in essence some trial and error is required to set up the system to best suit your car, and more importantly your driving style.
If you do see an engine light, don't worry this is your engine that you're being "greedy" and if the system is turned down the light will either go out straight away, or after a certain number of full ecu power downs.
We're here to
help virtually 24/7 so if you have any problems or further questions please don't hesitate to contact us, thats what we’re here for
If you'd prefer to have a chat, then simply reply to this email and include your phone number and well try and give you a call.
Thanks for emailing and hope you understand why it's a small yet important part of getting the best from your purchase
