What is the procedure from start to finish to code one touch mirror closing with the fob?
I'm new to this. My previous concerns I had posted about have all be resolved with a reset.
Ok chaps i have a Obdeleven from when i had my Sirocco.
When i try to do some coding i put in 31347 in the security access code in it says invalid code ( also does this with a Vagcom lead ).
My car is a Seat Leon 2009 FR Diesel with 170bhp CR Engine.
Has the security access code changed on this car ?
The code is usually given to you on the screen for you to just copy, shouldn't be a reason for it not to work
Ben,
Thanks for the info.
I just went to the security tab then put the 31347 into the window, i thought you had to do that to get the mods working.
Do you only put the 31347 in if it asks for it ? if not just carry on ?
With my sirocco i did not have to put security code in to do most mods.
Is it different with the Seat Leon ?
Have you a foolproof way of getting these mods to work in Obdeleven ?
Cheers.
Ben,
Cheers.
When I was doing my adaptations I used posts in this thread as well as https://translate.google.co.uk/tran...atleon.net/viewtopic.php?t=116700&prev=search
A lot of people post the codes required in their code but like I say when I had mine in the code was under or above(I forget) the box that was asking for the code
Gah, just realized i ordered the wrong version. Not the PRO version. Is it possible to uppgrade in the app? Is it the same hardware?
Maybe a stupid question :
- i have reverse camera, no pdc. Can this be activated without hardware mod!
-what is park Pilot?
-traffic sign assist, not activated for me. Can i enable this with obd11?
You can upgrade to PRO from your version, it's about another £20 though. Same hardware so worries there.
Park pilot is just the name for the parking sensors and optical display package as far as I know, without the rear sensors you can't upgrade with software alone.
Traffic sign assist will require the forward facing camera. You may have this if you have lane departure warning, but I have no idea whether you can enable it with obdeleven or not.
2015 Leon ST FR 184 DSG
As far as I'm aware traffic sign assist can be enabled if you do have the front facing camera but people have reported it being trippy sometimes.
As the previous poster says park pilot is the radar, looks like this on the infotainment...
traffic sign can be enabled if you have front camera. i did this mod, working fine, but every time i start the car, after few minutes error pops up - traffic sing recognition restricted. it only shows up one though so i just ignoring it. From what i read on the other forums its something to do with sat nav and the country you drive in. i have not found solution to this as yet though....
A stupid question, is the camera on the front you refer to the sensor for the active cruise control and lane departure?
Its the one on your windscreen,behind the mirror. It also operate lane & high beam assist.
Sent from my Nexus 6P using Tapatalk
http://www.ebay.co.uk/itm/381608950335?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
No error message displayed on mine but the OBDeleven app apparently has a mod to overcome this
Just got these fitted . Great job and no errors on mine either. Thanks for the info.
Just a thought though.......what maniac thought it was a good idea to have the N/S bulb covered by the washer bottle (my FR has the winter pack) I was able to get to it by removing the engine undertray that attaches to the bumper. Bit of a faff to change a bulb but it's worth it for the matching light colour.
Oh thanks for that, want to change mine as well but was hesitant as everyone says you need to remove the front bumper, your way sounds much easier and safer for the paintwork!
I did the obdeleven coding for the bulbs anyway after fitting as I noticed it increases the brightness to 127 when coding, the same as when increasing the interior door leds and the reverse bulb as well. It definitely worked on the interior door ones but I'm not so sure about the reverse one or the fogs.
I've also coded for cornering fogs and fogs with high beam. Work a treat and now looks much better as they match.
It is still tricky to change though and you will have a good deal of swearing but it can be done( I don't have small child's hands either:D) and is a lot easier than bumper removal.
If you take the six t20 torx bolts out on the n/s and along the front bumper the undertray should be able to be pulled down without having to remove it completely. You'll need to jack the car up on the n/s as well for access.
Tried to change the display on the infotainment and now have a blank screen that won't function? I've changed it back to skin 1 but nothings happened? Help please
