familiarise yourself with ross-tech website for vag specific codes.
It can be the map in the car (even std one has this fault) and it can be maf related also
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Power Loss
Possible Causes
Leaking Hoses and/or Pipes between Components
Turbocharger Recirculating Valve (N249) (Diverter Valve) faulty
Throttle Body dirty
Vacuum leak
Boost Pressure Control Valve (N75) faulty
Possible Solutions
Check Hoses and Pipes between Components
Check / Replace Turbocharger Recirculating Valve (N249) (Diverter Valve)
Check / Clean Throttle Body
Perform Throttle Body Alignment (TBA)
Check for Vacuum leak(s) including PCV system
Check / Replace Boost Pressure Control Valve (N75)
Special Notes
When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve
If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
When found in 1.8T engines, such as the (3B) B5/B5.5 Passat, check the PCV "bleeder valve". Example part number 06B-103-245
One way to
troubleshoot the
problem is to pinch closed the vacuum supply hose that attaches to the bleeder valve to see if the excessive crankcase vacuum is resolve resulting in a smooth idle.
