I'll post some pics once I'm over my 15 posts (nearly there)
Good mate! The A92 was shut at slip off the M90, so took over an hour to get up from Edinburgh!
Apart from coming home, I nipped out for a run to Kirknewton and back. I love it! Coming from the SE is such a difference. Everything feels a bit tight just now, so hopefully loosen off after a few thousand miles.
Android Auto is fantastic and I've had a muck around with all the options/lights etc. Any advice on the dipping the left mirror in reverse? Ticked in the settings but can't seem to get it to learn when selecting reverse? Also is reversing sensor purely just a tone? No guide on the screen?
Thanks in advance!
I now have had my FR 1.4 Eco Tsi Tech and I'm in the same position, I cannot for the life of me get it to dip the wing mirror even after following the instructions in the manual, Did you manage to figure it out??
I have a guide on screen for the reversing sensor but I also have the camera pack. When i move forward after being in reverse It will then show me the direction the front wheels are facing with the angle etc
Yes.
Move mirror joystick to 'L'
Select reverse
Adjust mirror using the joystick to desired position when reversing.
After that, the mirror should move to normal position when taken out of reverse. Note that to have the mirror move to the reversing position, the joystick MUST be in position 'L' each time.
And thats why it doesnt work, the manual says select R!!
<snip> ... the Seat Sound System is disappointing (so far). But plenty of time to get to know it all better over the weekend.
I'm wainting...
About the sound system how bad it is?
