Tell
To answer a lot of the technical questions of the Ateca the full workshop manuals are available by an hourly or daily rate for download as PDF files. You can browse but can't download if you don't pay.
Circa 8 Euro's + VAT gives you the ability to download in an hour the complete set of PDF maintenance and workshop manuals for the Ateca (pretty vast) + the SSP training guides for staff. Also on the site is recall information and host of other information. After the car has been serviced you should also be able to see the record of what was done.
(Registration from December 2025 is for commercial customers. Selective box filling is required.}
If you buy an hours time, probably go onto the maintenance and workshop manuals download, then go onto the SSP training manual. It appears that if you don't move out of the PDF download area you might be able to complete a full download if the time does run out, but obviously what you can do in 60 minutes is dependent on internet speed.
A word of warning, when paying by credit card it wants your address in European style:
Street, number
Else if wont' validate your credit card correctly.
Probably it's also a good idea to go online before the car is serviced so you can check recall notices, software updates and download any updated maintenance / workshop manuals. Essentially it's like having a big Hayes guide online. It's a good set of reference materiel on the Ateca.
(Credit this to Metalsman)
Nb. Note during 2023 or there abouts the VIN build code lookup tool was dropped, the rest is there on the re-designed site.
Reactions: Butty
https://erwin.seat.com/erwin/showHome.do
7 Euro's + VAT gives you the ability to download in an hour the complete set of PDF maintenance and workshop manuals for the Ateca (pretty vast) + the SSP training guides for staff + VIN build data. Also on the site is recall information and host of other information. After the car has been serviced you should also be able to see the record of what was done.
If you buy an hours time, probably best to download the VIN lookup build data, go onto the maintenance and workshop manuals download, then go onto the SSP training manual. It appears that if you don't move out of the PDF download area you might be able to complete a full download if the time does run out but obviously what you can do in 60 minutes is dependent on internet speed.
Street, number
Tell, sounds too good to be true.
I bought an hours access with a very fast internet which downloaded each manual as fast as I clicked on it. But the bit I wanted, i.e. vehicle specific information, failed. It reported "It is not possible to call up vehicle data. Please contact your workshop or importer responsible for your market if you want further information"
I'm hoping to do most services myself now that the car is out of warranty at over three years old and 20K miles. But there was no information about what has been done, what upgrades are required and what the recommended service involves. But I did get a load of bulletins and self learning modules.
  • Haha
Reactions: sandancer and Tell
Yes I've never seen the service record on it but I might have not looked close enough. Suppose to be there. The VIN lookup with build codes is useful if there are issues about what is in the car.
The maintenence manual which you will have downloaded covers when maintenence task needs to be completed. You could work on the basis that it was on a Seat / Cupra plan then check what isn't done against what is recommended in the maintenence manual. The plans are designed to get the minimum cheap service before the car is passed on in a PCP agreement. Some people just stumble through on the two year long service so it might not even been serviced if it went in on the third year ?. There is a display that tells you when the oil needs changing part of the cars system. That trips over the cheapskates that think they can spin it out to two years. All depends on the mileage.
You could probably get a dealer to lookup whether it was on a plan in checking what needs to be done in a general enquiry to see how much it would cost.... that would answer your question. Then say you'll think about it ?.
Circa 7 Euro's + VAT gives you the ability to download in an hour the complete set of PDF maintenance and workshop manuals for the Ateca (pretty vast) + the SSP training guides for staff. Also on the site is recall information and host of other information. After the car has been serviced you should also be able to see the record of what was done.
If you buy an hours time, probably go onto the maintenance and workshop manuals download, then go onto the SSP training manual. It appears that if you don't move out of the PDF download area you might be able to complete a full download if the time does run out but obviously what you can do in 60 minutes is dependent on internet speed.
Street, number
The ERWIN link has moved to https://seat.erwin-store.com/erwin/showHome.do
Hello Steven33 and anyone else.
I have been spending time reading all the references here, relating to Workshop Manuals and of course checking Google.
It seems that Erwin is no longer available to those outside the industry... and I can not make it work to even search, looking for what content is available. It was shut down last year.
Never paid for any workshop manuals over the years and different marquees of vehicles but it looks like I will have to now.
Cupra Ateca VZx... 2024 does not even seem to exist anywhere out there... even on websites that need payment.
Just want to remove a few interior trim panels and run some dashcam wiring... the glovebox, the glovebox shroud, the rubber boot grommets between the hatch and the roof... nothing too difficult but a manual would be so beneficial.
Any ideas or direction would be greatly appreciative, obviously I want to find the correct information.
Cheers in advance,
Stephen
You can register for erwin but you register as a business now. Just give your name in the business name. If you have ever been self employed you get use to that. You become a sole trader...
The manuals itself may not always be clear but are useful. Two hours of erwin time should do the trick. You download all the pdfs that you will ever need. Build codes as well and ssps if you see them. You only do it once. Save the pdfs and job done.
Thanks Tell, yet again.
I do have a Business Name and I have fast internet at home, are the manuals accurate?
Do I pick model and year, or can I use my VIN ?
Sorry, also... pardon my unintelligence but what is SSPS and what does build codes mean ?
I don't have access to "VAG"obdELEVEN, so is that what the codes would be for ?
SSPs are the dealers training materiel so is interesting. Use your Vin then the manuals are self explanatory as to which to download.
Reactions: steveyoshi
Sounds good, I will wait until I get home, with stable fast internet and take a look on a PC.
