Mar 21, 2024
15
I’ve current got a battery drain on my Seat Ateca and when this started I got a EML light with a fault code of P148C - typically indicates a problem with the Selective Catalytic Reduction (SCR) (AdBlue) system's reducing agent heater.
I’ve read online that the heater could remain on after the ignition is switched off causing a constant drain.
I was just wondering if anybody else has had this issue and if so could this fault be a possible cause to the battery drain?
Thank you.
