nike32
34
I know there is a lot topics with P1335 code.
If I drive with full throttle it never comes.
But if I cruise with half the throttle and it starts to build pressure on with rpms being low, it throws EPC light and no throttle response.
I noticed someone in other topics mentioned if the boost will start to rise (spike) with rpms being under 3k it will throw this code.
But none of the topics suggested a way to fix it.
Maybe new programm, but thats expensive for just trying.
Ross-tech.com is the best place to look up the codes for the leon........There is a link here for you with quite a few suggestions as to what could be the issue. http://wiki.ross-tech.com/wiki/index.php/17743/P1335
Everything is fine on that list.
All sensors work and no leaks.
I have access to Autodata, so I had the same information, but no help.
Отправлено с моего SM-G935F через Tapatalk
Ah right, in that case other than being a poor remap i don't know.
I am also thinking poor remap.
I will do today one more boost leak test, but I dont think as almost every piping is new.
it should'nt do that with maf unplugged
you have other issues.... Smoke leak test for leaks next
No leaks.
Atleast big ones.
Sprayed with soap water every hose, but nothing.
smoke test to verify this.. I doubt you will find all leaks with soap and water method to be honest
