Bad misfire, help needed!
kyleb123
167
Need some help with a bad misfire on my stg2+ FL Leon cupra has developed. It starts ok but sounds really rough with a constant misfire, almost like a Scooby sound. It's in limp mode aswel with the EML flashing sometimes, plugged it in with my basic scanner & it come up as a misfire on cylinder 4 P0304 code.
Changed coilpacks & spark plugs but still same. I suspect maybe a bad injector or bent valves?
Anyone else had this problem?
boggle
117
KENT
It very likely to be a faulty injector, its a fairly common problem. But get a compression test done to rule out other more serious problems
kyleb123
167
Compression test done, no compression on cylinder 4 :( will this still be a faulty injector?
Speed-FReek
1,110
18
United Kingdom
No compression will either be a problem with the valves or the rings on that particular cylinder. Time to take the camshaft cover off and see from tbe top if there is any obvious valve damage, or try to use an endoscope/borescope through the spark plug hole to see from the inside if there is any damage to the valve heads.
kyleb123
167
Doesn't sound good that. If there is damaged valves, is the engine still salvageable?
Rusty2k
715
140
Did you get no compression at all or just a low reading? What was the compression like on the other cylinders?
Could be a problem with the valve train, injector (incl. seal), head gasket or bore / ring damage.
Inspect what you can and if nothing looks obviously faulty then get a leak down test done.
Speed-FReek
1,110
18
United Kingdom
Rusty is right. I had a brain seizure earlier and forgot that the TFSI engine in your car utilises direct injection into the cylinders, so yes, a bad sealing injector could cause poor compression on the TFSI engines. Just do as Rusty recommended.
EDIT: Illustration added (injector is on the left)...
kyleb123
167
Had the car sorted, it was bent valves after all :censored: cars running good now after a quite hefty bill. However it's seemed to have developed a new problem, sometimes when dipping the clutch the revs take a while to drop, my cruise control has also stopped working?
Clutch switch gone bad I presume?:think:
kyleb123
167
kyleb123
167
UPDATE: On going issue, replaced the clutch switch & still the same. Random stalling when coming to a stop, sometimes the throttle blips by itself. Also when the car starts from cold there's a slight delay from starting the car to it high idling.
Anyone had these symptoms? Throttle position sensor?
Jfox
395
Would it not be worth getting it scanned with VCDS or something?
I know the basic scanners are good (i have one myself) but not all codes come up.
