Hi, I recently installed coilovers (DTS) on my ibiza and since I don't have an impact wrench to remove the strut mounts from the original shocks I decided to buy new ones to use since the original ones have already almost 60k km so why not.
One thing I noticed is that the nut supplied, that tightens the strut together (the first nut) wasn't the same as the oem as you can see in the photos the oem nut has a washer thing to help center the strut mount and keep it together with the strut itself which didn't happened with the coilover as the nut doesn't even touch the the strut mount so it's loose.
I was a bit doubtful to whether it was safe or not, but I read the manual and they said it was supposed to be used with the oem strut mounts so that's what I did.
When installing the coilovers I tried to line up the strut mount best as I could so it sat evenly. Then tighten the guide and be done.
Been riding for 2 weeks I think and yesterday I decided to test the XDS on Strong setting on a curvy road and apart from the tires squealing a little, the car coped surprisingly well I would say, no loss of traction or anything similar. It felt like a kart.
Today I went to check the torque on the strut mount nuts and the left one was a bit loose, since it was loose I decided to check the strut mount to see if it moved.
This is what I saw, are they damaged or is that normal ? The original ones had that too but not so pronounced. I'm thinking if this was caused by the spirited driving I did or if it was the camber since it is even lower now ? I had H&R springs before.
