Cleaned and polished. Noticed some lacquer peeling
Fitted new rear struts for boot so it pops open as well as the spray washer jets to replace the crappy originals
Just strut swap. They are stronger so it's harder to closeGetting the boot to open automatically: is it literally a gas strut swap and it will open automatically with the key press, or are there any obd11 modifications that you have done?
Ive had mine on for around 6 months now and they are starting to loosen off, i didnt really use the boot prior to my kid being born so id imagine if they are getting used regularly it will be easier to close quicker than mine
Howdy! What’s the difference with the new washer jets?
Seat Leon Cupra 290 DSG Black Edition (Alor Blue)
Performance: Racingline OEM+ Stage Two Mapping | Racingline R600 Intake | Racingline Turbo Inlet Pipe | Racingline Turbo Elbow | Racingline Muffler Delete | OEM NGK Audi RS7 Spark Plugs | 034 Motorsport Dogbone Mount | GFB DV+ | Milltek Large Bore Downpipe | Pipewerx Custom Cat Back Exhaust | Forge Turbo Blanket
Interior: Koonlung K1S Dash Cam with BlackVue Power Magic Pro
Exterior: TRC Front Splitter | Foliatec Exhaust Paint Gloss Black
Two in front windscreen pillars, two in each front door, two in rear 3/4 panels ( I've an SC ) and one sub in boot spare wheel well and one on top of the centre of the dashboard. Excellent sound and worth the upgrade.Anyone have a description the location of 10 speakers with sub?
Sent from my Pixel XL using Tapatalk
What's the difference between SSS and BeatsAudio then?Is it the same subwoofer for both?
Leon's Seat Sound System and Beats Audio both have 10 speakers in total.
The speakers are front tweeters, front midbasses, center channel speaker, rear tweeters, rear midbasses and a subwoofer.
It is yet unknown if the speakers are the same in SSS and Beats Audio.
Part numbers for the speakers would need to be checked dealer or ETKA etc.
Seat Sound Systems subwoofer is 6,5" in size and sits inside a 18" space saver spare wheel.
Seats online new car configurator forces to select a 18" space saver spare wheel when selecting Beats audio, so my guess is that the subwoofer still sits inside the 18" space saver spare wheel.
Size of the Beats Audio subwoofer is yet unknown, but my guess is that it is 6,5".
Seat Sound System uses infotainment units internal amplifier with total of 135W.
Beats Audio system has a separate 340W amplifier that is located below front seat.
