johanbaguca
27
Hi guys,
Found this photo online thought maybe someone had more info on this, was it just a concept?
Also check this page http://www.museoseat.com/modelos/toledo-2/toledo2-castellano.html
It has all info available on any Seat spec sheets technical info but its in spanish,
This was talked about quite some time ago as a concept, never happened here in the UK. There was interest but obviously not enough for SEAT to bring it out. The car magazines all stipulated about it being made with several articles published.
Shame actually looks very good sleek and not exaggerated, should be quick as well
There was the Toledo 20VT which was pretty quick with the same 180PS engine as the Leon 20VT (Cupra)
Not quite the same as the later 210PS / 221PS Leon Cupra R though.
And the Mk2 Toledo Cupra race car in European and British Touring Car Championships.
if I'm not mistaken the Toledo is lighter than the equivalent leon too
Correct ,
Leon Cupra r comes in at 1376KG
Toledo20VT is 1316KG
Both quoted from Parker’s
And if you put the cupra r bits on the Toledo (brembo brakes, suspension , bigger rear brakes the twin intercooled bigger turbo 225 engine ) it would probably weigh more
I think the weight is in the tailgate on the leon mainly but it wouldn’t surprise me ,
The 20VT has the cupra r rear vented brakes from the factory also .
As you say I I bet they would come in the same but there’s only what 60kg in it , not even noticeable
