That’s the brand I had on the Mk2. Shame...
Reckon it woild be a safe bet to add heko deflectors without adding excessive noise?
There’s a thread somewhere that made me buy my Heko deflectors - someone had put a strip of black silicone along the top of the deflector where the window would sit in the deflector and it get rid of the noise.
Good to know, did that work for you?
I’ve not done it yet - but I will be doing
Haha ok, how bad is it at the minute?
It’s only noticeable at motorway speeds, but it sounds like the windows just aren’t closed properly.
I wrapped my badges a few days back. I now think the car looks as aggressive as it should do from the front. It's a pain in the ass to do unless you're very good with wrap Being the 3rd time I've used the stuff it's still tricky to get right. It's a good 5ft mod though, more of a proof of concept to make sure I like the black so I might paint them down the line. Happy to say the car is now chromeless on the exterior.#DeathToChrome
Ya its gloss black. I've used plasti dip before but never used the glossifier with it which is supposed to give a good enough gloss finish. The wrap is fairly time consuming too, if you're picky about it like I was you could easily spend 2 hrs getting it right.Looks good, did you do it in gloss black wrap? Might be an option as I don’t want to plastidip as it’s difficult to get a gloss black finish. I don’t want to paint as it’s a right faf and very time consuming.
Cheers lad, she's getting there slowly. Follow me on Instagram if you want to keep up with the planned changes for wheels, exhaust etc.That spec![]()
Looks well lad. In future try and remove the newspaper and tape while it's still wet and tacky. If you peel the tape while it's wet it tends to tear along the seams better.
