Hey guys and gals!
Long time no see, been a busy bee but finally able to get some proper work done for the little beauty! =)
I'm currently getting all the service parts I need, though kind of stuck now specifically on the Water Pump... I've sourced an auxiliary water pump which is on its way, I'm wanting to purchase Cambelt Kit and Water Pump, so far I'm kind of settled on the SKF Cambelt Kit and Water Pump, only issue is I think from the looks of the SKF Water Pump the propeller looks plastic? Another one I've looked at is the Febi Water Pump which doesn't look plastic but states cast aluminium?
SKF - VKPC 81218
Febi - 24360
SKF Cambelt Kit + Water Pump
I am looking for a little reassurance from this on whether to just buy the whole kit and not go with the Febi Water Pump, or to select just the SKF Cambelt Kit and then the Febi Water Pump? What do you lot generally go for? I wont be doing this service myself the garage I trust will be doing it for me
Thanks in advance!
--Lee
SKF - VKPC 81218
Febi - 24360
Thanks in advance!
--Lee
