Car menu only disables stability control. Doesn’t disable traction control. Holding the button down is the same.Damo, when you say turn the traction control off altogether you can do this via the car menu and i am sure you can code it off with VCDS / OBD11
Would be interested if VCDS can be used so that the holding the button down disables it all and not just stability.
