Dash cam connecting
Steve Turner
Stockport
Hi folks from a newbie,has anyone managed to wire up a dashcam to a switched feed and if so how.My passat was easy to do as the fuse box was just under the dash,thanks.
Maypack
Apr 20, 2014
3,175
2,328
Gods Country - West Cumbria
Steve Turner
Stockport
My dashcam is powered from the OVD socket. It’s a switched unit that allows recording when parked and has a cut off so that it doesn’t take excessive power from the battery.
https://www.halfords.com/technology/dash-cams/dash-cam-accessories/blackvue-obd-power-pro-cable
That may be an option.Mine is a Mio with sat nav and the consumptions quite high and blew a normal dc to usb adaptor in a couple of days.Is the Halford one the normal mini usb type,I couldn't see any rating on it so it may only be suitable for the Black vue.
Steve Turner
Stockport
Here’s more info on the power connector. I’m sure it should connect to any cam with the same power socket.
https://www.blackvue.co.uk/index.ph...necta-obd-ii-power-controller-detail?Itemid=0
Must admit it does look ideal, will have a look, thanks for the info.
Steve Turner
Stockport
Now I have had time to have a good nosey I have found a convenient tap off point in the fuse box under the dash so all sorted without any outlay,thanks for all suggestions.
