New 67 Plate Leon - Rattles!
Luke_bank
378
45
What i did on an older car is put insulation tape around boot and rear seat latches. Did sort it.
Sent from my SM-A520F using Tapatalk
Where did you put it in the boot? Between the trim and the body work?
Gavin290
40
Not yet! I’m resisting taking it to the dealer.
My rattles normal occur when temperatures are below 5c, not sure why.
Is your boot rattle like a tapping noise?
It sounds like something hanging and just knocking against plastic. I thought it was the seatbelts at first tapping as someone else mentioned. But it wasn't, I had a Leon MK2 and that had an annoying vibrating noise that I worked out to be the rear door handles!!
Why can't they just make a car with no noises or rattles?
Before this I had a 2005 Civic Type R, it didn't have any noises!!!
russbellrfs
286
26
The circled areas on the photo
Gavin290
40
I've tried insulation tape on the boot catch, and it made no difference. Gave my back seats a shake and they are solid, there's no play in them so I don't think it's those?? Looks like this must be a common fault as me and Luke both have the same issue!!
russbellrfs
286
26
Worth a try. Probably a loose cable flapping between panels...which u will never find!
Luke_bank
378
45
I have more than a boot rattle now . Head on at around 60mph. Other driver arrested!!
SRGTD
2,784
1,645
Wow! That looks nasty. Hopefully you and anyone else that was in the car are OK and no one was badly injured; a car can be repaired or replaced. Looks as if the airbags deployed, as you would hope they would in that sort of impact.
Although there’s extensive damage and I would guess your car’s a write off, the passenger cell looks as if it stood up remarkably well to the impact.
Gavin290
40
Oh my god!
Hope you are okay dude.
I've fixed my rattle (I think) but this puts it all into perspective!
Luke_bank
378
45
Pretty much all air bags deployed...I think. My passenger reckons there were some in the footwell that went off?
Needless to say I’m in a lot of pain, fractured my sternum.
Just want to know what happens next, but being the weekend I’m not getting anywhere fast.
russbellrfs
286
26
The bit that puzzling me is the headlights still work!!
Lmbarrett83
1,538
619
Sheffield
They are the new hazards. Mine came on automatically in my collision, but as it is pre facelift the whole cluster didn't light up like Luke's.
Sent from my Pixel XL using Tapatalk
russbellrfs
286
26
I know the DRL/sidelights are also indicators, which on a sidenote look awesome, just surprised they were still functioning!
Lmbarrett83
1,538
619
Sheffield
Ah ok, fair enough.
Yeah they do look the part and are definitely very robust.
iScoTT29
191
52
Hope you and any others involved are going to be alright! Nasty crash but car has stood up to the challenge under a 60mph crash. Just puts into perspective how safe cars are these days!
Diamond123
30
I have a rattle on my 67 plate on the driver doorcard but nothing major so not bothering to get it looked at as they will probably make it worse.
A rattle from the boot area is exactly what I was experiencing for weeks and the cause of mine was the rear seat seatbelts. When I have had passengers in they have obviously used the seatbelts but not placed them back in the plastic holder thing (have no clue what you call it). So when they arent in the belt moves as you drive and rattles off the plastic however, when its seated in the plastic holder the rattle stops.
Scott, judging by your pic we have literally the exact same car and the same problem lol. My car is identical to yours and i have that stupid rattle. Mines coming from the passenger side door beside the B pillar. Did you ever get yours fixed?
iScoTT29
191
52
That pic was just off google sadly :p I have had the car 1 year now and now used to the rattles, just turn the music that little bit louder :bleh:
