I paid €125 to have a resonator delete custom made and fitted so £100 for fitting alone of a pre made part is expensive. Just head onto Google and call every single exhaust shop around you and see who is cheapest.
Reactions: Tully1980
FWIW, it’s about 30 minutes work. It took my local exhaust place a bit longer as they had lost their new exhaust cutters and it took them about 10 minutes to find them!
Anyone who tells you it’ll be a complex job is talking out of their arse..! If yours is anything like my Cupra 300, it’s one cut and one clamp to remove the original piece, and then 2 clamps to fit the res delete..!
Thanks for the prompt replies! I’ll phone around today and report back.
Not sure if mine is much use but mine was a custom job from Powerflow, cost me £194 but that was the res delete and replacing the stock exhaust tips for quad tips
Have u got any pics of the quad tips?
Sent from my SM-G935F using Tapatalk
Would’ve preferred them a bit larger but due to the diffuser exhaust sections being made for the oval pipes these are the only ones that could fit it seems, also look a bit angular but that only seems to be on camera for whatever reason.
Yeah thats a shame they cant go any bigger. Still they look good
Reactions: cupra300uk
I think they look great. I’m tempted to get twin Akrapovic tips for mine but I don’t think my lease company would like me hacking the exhaust any more
Cheers, still think they should be quad tips as stock like the S3 or Golf R but of course SEAT and Skoda aren’t allowed the good stuff
I wanted those too but the price just couldn’t justify it, would’ve preferred a proper set of tips and I would also like my car to be even louder ‍♂️ and yeah let’s not talk about the lease until it finishes...
You can get a pair of twin Akrapovic tips to fit the Cupra for about £80 off Ali Express... They’ve even spelled Akrapovic right
Are they legit?? Wish you would’ve told me that before I got these tinny things on! would prefer the whole exhaust system doing with that though tbf
They’re about as legit as a £20 pair of Nike Air Max
But they do look the part and someone else on here had some fitted to his Cupra ST
Ahh is this that Deano fella with the white ST? Sorry if I’ve got your name wrong and you’re reading this!
If you could get a Akrapovic exhaust system for a cupra it would probably cost about £2500 and that’s not including fitting. Are the the real thing...no. But the look bloody good..
Had the res delete on the car today. Sounds mint.
It is loud though at certain times and at cold start. Does it quieten down a bit over time when it carbons up a tad?
It’s definitely louder off a cold start, but mine takes less than a minute to settle. Mine isn’t much louder unless I floor it. The engine note is definitely different though - mine has much more of a throaty burble to it which I love..
Reactions: ChrisJKM
Mine is louder off cold start. Only over 70 do you start to notice it on a dual carriageway. Like you said when u floor it its more noticeable. Sounds more like the car it should. I didnt want too be too loud to draw attention just enough to know it has a bit of power. Have too see how it sounds after the map.
