Leighton267 Active Member Oct 10, 2018 11 0 Oct 10, 2018 #1 My bonnet lever to pop the bonnet snapped, any ideas how to open it without it ? Thanks in advance
Thai-wronghorse Self proclaimed Cupra R addict & butcher! Dec 3, 2015 2,239 1,126 Kent Oct 10, 2018 #2 Which lever, the one inside the car or the one poking through the grille? Sent from my SM-G960F using Tapatalk
Leighton267 Active Member Oct 10, 2018 11 0 Oct 10, 2018 #3 Thai-wronghorse said: Which lever, the one inside the car or the one poking through the grille? Sent from my SM-G960F using Tapatalk Click to expand... Inside the car mate
Thai-wronghorse Self proclaimed Cupra R addict & butcher! Dec 3, 2015 2,239 1,126 Kent Oct 10, 2018 #4 Unscew the base of the lever and disconnect the cable from it. You can then pull the cable with a pair of molegrips or similar. I've got spare levers if you need one? Sent from my SM-G960F using Tapatalk
Leighton267 Active Member Oct 10, 2018 11 0 Oct 10, 2018 #5 Thai-wronghorse said: Unscew the base of the lever and disconnect the cable from it. You can then pull the cable with a pair of molegrips or similar. I've got spare levers if you need one? Sent from my SM-G960F using Tapatalk Click to expand... Where you based, might take you up on the offer and so give it a try tomorrow cheers
Thai-wronghorse Self proclaimed Cupra R addict & butcher! Dec 3, 2015 2,239 1,126 Kent Oct 10, 2018 #6 I'm in Maidstone and regularly break mk1 Leons. I can post most stuff. Sent from my SM-G960F using Tapatalk
Leighton267 Active Member Oct 10, 2018 11 0 Oct 11, 2018 #7 Thai-wronghorse said: I'm in Maidstone and regularly break mk1 Leons. I can post most stuff. Sent from my SM-G960F using Tapatalk Click to expand... How much ?
Thai-wronghorse Self proclaimed Cupra R addict & butcher! Dec 3, 2015 2,239 1,126 Kent Oct 11, 2018 #8 Check your inbox mate Sent from my SM-G960F using Tapatalk
