Thanks a lot for your quick reply. Did i get this right, that your TMC/headunit was broken BY the update?
Best
Josef
Do you have access to VCDS or
OBDeleven Pro?
There is a setting in the 5F module that sometimes gets changed causing the TMC failure.
This is what I found,
Infotainment: Enable TMC ?
Doesn't work with: Argentina Models - MK7, Argentina Models - MK7.5
STEP CONTROL UNIT LONGCODE BYTE LONGCODE BIT DEFAULT SETTING NEW SETTING
1 [5F] Information Electr. Byte 13 Bit 03 - Radio Text Plus (RT+) active [STANDARD] unchecked checked
STEP CONTROL UNIT ADAPTATION CHANNEL PARAMETER DEFAULT SETTING NEW SETTING
2A [5F] Information Electr. - Fee-based traffic information (TMC) 65535 (disabled) 0 (dev options)
2B [5F] Information Electr. - Fee-based traffic information (TMC) 65535 (disabled) 3 (VW TMCPro MIB1)
2C [5F] Information Electr. - Fee-based traffic information (TMC) 65535 (disabled) 1024 (suna/australia)
2D [5F] Information Electr. - Fee-based traffic information (TMC) 65535 (disabled) 1537 (canada)
2E [5F] Information Electr. - Fee-based traffic information (TMC) 65535 (disabled) 32768 (VW TMCPro MIB2)
2F [5F] Information Electr. - Fee-based traffic information (TMC) 65535 (disabled) 32771 (online traffic + VW TMCpro)
Security Access Codes: 20103
(*) Try different numbers until one works.
(**) For TMC to work, "TP" and "RDS" need to be activated in the set-up menu for the radio.
(***) It may take some time for the new facility to be established and for the initial set of traffic reports to be downloaded, in some cases hours.
On my car I had 'before and after' adpmaps and had to change the setting from something like 32767 back to 15 and TMC then worked (UK).
