Followed my wife to our local dealer so she could drop off her Leon Xcellence for its first service. Whilst there saw these wheels which I thought looked pretty sweet.
I’ve no idea if the price is good or bad but they would have looked great on my old FR.
Met a few of the members off here at the Blackpool meet and won this bad boy as I had the dirtiest car (not by choice)
Excellent work @Jimbobcook
Also thanks to @Sharpy for the Meguiars cleaning kit. Looking forward to using it to try and win the cleanest car next time
That is a superb model does anyone know where to get these? Cheers
Look like great value be good with winter tyres perhaps.
I've got the single with the front resonator taken out and the rear muffler still in. have you got any videos of both out?
right okay that could be interesting. I havet any videos at the moment but will get some done and post up
Today I took my 280 Sub 8 in for the brakes to be electronically bled & fluid changed, mainly because of how spongey the brake pedal felt compared to my 290 which didn’t have the Brembo’s. The bite was always towards the top of the pedal range & didn’t require multiple pumps to stop on a dime.
Anyway I got it back & it’s actually not any better... the Seat dealer says this is because the pads are down to 4mm & there’s ‘extra distance to cover’ for the pad to contact the disc. To me this doesn’t seem correct but I’d be interested to see what you guys think
I'm no expert and I understand the theory of what they are saying, but I'd still call BS on that. When my 280 needed new pads (not Brembos I admit), the pedal feel didn't change after the new pads were fitted (it was never bad prior to the pad change).
In fact thinking back to the Stoptechs on the MINI, after 60k and needing new pads the pedal bite point hadn't changed on that either...
I think the service desk guy is thinking of brakes that you’d see on a mountain bike which retract back to a set position. But on a car it’s the rotation of the disc which pushes the calliper open to say 1mm from the disc surface. The depth of the pad sat beyond the surface is somewhat irrelevant
Yeah I would not expect the pistons to be 'sucked' back all the way into the caliper.
Not ideal, maybe worth taking it into an independant VAG Specialist. Where are you based?
Reactions: paddy6789
Mrs Wilson was particularly impressed with her fuel consumption yesterday, on a short trip through the roadworks on the M6 to Crewe. Personally I didn't think this mpg was possible in a 300 ST 4 Drive!
Reactions: louiskopite
Impressive. My wife would probably be in the 20s. I really can't see how she can get mine so low when she drives or, if I let her
I certainly see that sort of figure on long distance motorway driving (when at a steady 70) to the last two meets, but in normal driving its a bit lower :)
On nearly all modern calipers - it is the seals that retract the pistons from the disc.
the seals distort slightly when you apply the brakes and retract the pistons as they straighten up afterwards.
If the discs are knocking the pads back - you have disc runout and it would be felt as vibration when braking.
Reactions: Walone
What a croc of shite.
The whole point of hydraulic disc brakes is that they self adjust.
From brand new pads down to 0.5mm of pad left - the pads do not retract any further
Reactions: Hogey
