Pedrocks
27
7
Hi all,
I've got my new maxton design splitter (pics to come) and need to fit it on my Cupra 300.
However after using the car jack today on the front car jack points, I can't see where I should place the axel stands to rest the car on. If i use the car supplied jack, there is not enough room on the jack slit to get the axel stand on at the same time. I don't really want to purchase a trolley jack if possible and was wondering if someone could share with me where i should place them?
I've seen some old threads but not found any definitive answer on this.
appreciate any help on this.
Anything bulky, metal and solid pref with a massive suspension bolt nearby:
Reactions: kazand and Pedrocks
I'd buy a decent trolley jack rather than rely on the horrid thing which is included with a typical car (barely fit for an emergency).
Reactions: Yellow fr
Interestingly I won’t use those points as it’s only alloy and I don’t trust it not to deform.... there are a couple of other locations you can use though.
I agree, used mine for the first time recently when I got a flat and was terrified the whole time, just feels very unstable.
Here's an interesting bodge, but probably not high enough for your job.
Thanks for that - I now plan to make something like those to put in the boot in case of a puncture. I'll stick to trolley jack + axle stands for normal use. BTW I never work under a car without multiple supports (3 or more from choice).
Hi all,
Take a look at this it may help.
https://forums.seatcupra.net/index.php?threads/getting-a-mk3-in-the-air.445439/
Yes, never get under a car supported by just a jack. Unless it has a mechanical locking system, which is rare.
Deaths from being crushed under cars are quite common here.
