Car meet this morning
Hey people jus put a deposit down for a mk3 cupra 290 on a 16 plate dsg looking to pick it up in 2 weeks cant wait but at the time being I own a lcr wich I'm still going to keep as my run around
Reactions: Jay280
Does anyone know what glue should I be using to fit a MD rear diffuser? +what screws please??
Also having an issue with closing the drivers door, need to slam them to close seems like the locking part gets stuck and doesn't catch the door each time. Any ideas how to fix or any part numbers if need replacing would be appreciated.
By MD Do you mean Maxton Design in which case I took the rear bumper off (2014 cupra) and used the supplied bolts to attache it - no glue was used and its been on there a while and been on the track a fair few times with no issues (so far).
All I did personally was screw a few extra self tappers (from the inside of the bumper) into the diffuser.
Cant help with the door I am afraid but if you are after part numbers I always use this site
Maxton design, yes
Mine came without any bolts so need to get something myself
More or less, in total how many have you used?
I will go and check later today, Do you also have the wings if so I found it impossible to get bolts to a place I could bolt them up so in the end I used M4 32MM Hollow wall anchors they did the job and had no issues.
@Miguel 7 Been outside the wings require 3 bolts on each side.
The main body requires a total of 6 bolts (the centre section has 4 and the outside has one on each side.
What I did was then screw in on the inside of the bumper to add a screw on each of the outsides.
I have pictures of the underneath if you want them just shout but from memory there should be pre drilled holes on it.
The actual Wings come with some double sided tape to hold in place.
No problem sorry it did not help, Did you buy it new or second hand, if new the web site shows it comes with a mounting kit and based on the picture it is a set of bolts, the picture on the website also shows it has some holes.
