Mine has leaked twice, both times it was the sump plug. There is now an updated sump plug which I’ve had no issues with since the dealer started using it.
The oil in mine gathered in the driver side of the under tray then dripped out through the hole to let water escape.
Yes. Had the sump plug issue with mine that was sorted with the revised design.
My notes on my oil change from 6 months ago say 4.0litres but cannot remember if that is with or without filter?
Noticed oil on my driveway, so asked the local garage ( non seat ) to have a look.
After reading up on here about oil issues, I expected it to be the sump plug, but garage says it's the sump itself that's leaking.
Dealer part, which will be £235 supplied ( to local garage ) and fitted.
Anyone else experienced this ? My car is 2013 1.4 fr with 81 000 miles on it.
Also, still on original timing belt. Time to change that too maybe ?
Not sure. By the time the car was ready ( they serviced it at the same time ) the undertrays were back on. .What part of the sump is leaking?
I had my timing belt done in January. Mines also a 2013 but had 50k miles. Done for peace of mind as I intend keeping the car for a few more years and it also keeps my extended warranty right.
