Ian Tate
18
leeds
I'm looking to purchase a good fmic and possibly get it fitted at the same place can anyone point me in the right direction. I live in Leeds so anywhere close?
cheers
Good option for a FMIC is an Airtec, you can get one from Awesome GTI (link below) along with a bunch of other places
https://www.awesomegti.com/shop-by-brand/airtec/airtec-intercooler-kit-for-seat-leon-cupra-r-1-8t/
Not sure on where you could get it fitted in Leeds as I'm from London but I'd assume that most garages would fit them as its a reasonably simple job.
Have you considered fitting it yourself?
hi thanks for the link. I have been in touch with R tec and they will supply and fit a welly cooler system for me at a good price. so I think I will just go there like thanks again dude.
Mind me asking how much, been thinking about getting one myself and airtec isn't far.
Have you thought about a custom set up? either done at a shop or done yourself? I worked out I could do one on my auq for around £200-£300, £500+ seems a bit excessive for an intercooler and 2 small bends.
Wellycooler, bar and plate, £70-£100, a few bits of pipe bends and joiners, say £100 for the lot, map sensor boss, £25, bov t piece around £15, self sealing take off port for the n75 is also around £15-£20.
Also that Airtec one is for a Cupra R, so it wont just bolt on the the LC, manifold is flipped as well as different boost pipes to the original coolers.
I have been quoted £575 for the welly cooler fmic and pipes Rtec set my last cupra up and I was more than impressed also they will do all the delets necessary for it to run better.
Reactions: bigT's lcr
Just thought this might be helpful. Unless your going hybrid k03s or bigger k04 then a Welly cooler is a little overkill and might give a little bottom end lag. If you plan to be sub 300 BHP then I suggest a 550x225x63mm core with 2.25" piping on the hot side and 2.5" piping on the cold side. This will give just as good a cooling effect and a little bit more punch down low as you wont be trying to fill an oversized intercooler core. Hope this helps.
https://18t-tuning.co.uk/intercoolers/
my new k03s has just landed and I'm taking it to a friend that is going to hybrid it also new manifold for it. I have just purchased a ported inlet manifold and 440 injectors. I'm hoping for 300+. we shal see once Rtec have done there magic with it.cheers dude
