Headlights haze on glass
Monsoon
79
7
My headlights seem to have millions of tiny micro-cracks on the inside of the glass units which are particularly noticeable when the lights are on. Anyone else got this or got it sorted?
No moisture/condensation evident, no obvious gaps/leaks, and thoroughly clean on the outside. The car is now 6 years old.
Monsoon
79
7
Thanks Kirky. Looks like a not uncommon problem, but no one on that thread managed to get it sorted. Would be interesting to find out if anyone has since then.
martin j.
1,996
891
Fife
I think my previous Leon 08 mk2 had similar on the headlights, didn’t seem to affect the light pattern or mot.
ZK_FR150
221
32
There probably isn't going to be any sort of easy fix for this I'm guessing, either bake the headlight so the glue melts and you can separate the lens from the unit and polish the inside of the lens if you are confident enough.
Otherwise replace both lights will be the only other option.
KoNG
473
98
Canning Town
some of the earliest model suffered from wrong filter fitted causing dust getting sucked in the light and this is exactly what you get after couple years running the light. SEAT wont take any warranty measure on this problem only one solution is replace the light if you not fancy baking and taking it apart.
RUM4MO
7,820
996
South Scotland
Of all the VW Group marques, SEAT do seem to be the worst offenders for many "lighting assembly" problems when you include the leaking/falling apart rear light clusters, I can't quite understand why that is happening again and again.
Kothaex
133
12
Just posting my example as I said I would. Not the best picture but I feel like it's the same issue as described above.
Jaco2k
AWD FTW
Mar 11, 2018
1,037
635
Tampere, Finland
www.youtube.com
My facelift lights look pretty much the same on a 2 year old car, but in my case, on both sides the auto-levelling has decided to give up often, requiring me to turn engine on and off for lights to level properly, so I am hoping they will replace both under warranty - currently case is under investigation and my local dealer is seeking approval for the repair.
I believe their solution will be to "first attempt a reset of the leveling system"
I needed to provide video proof, including the car license plate, for them to take action.
I feel I have a long fight ahead... But hopefully I will get the full lights replaced, which will sort also the foggy lenses from inside.
Reactions: MXP2090
