Lozzy15
Retrofit Window Washer Fluid Level Sensor - MK3 Leon
Lozzy15
Mods mods mods
571
377
Ilkeston, Derbyshire
Jimbobcook
6,150
2,533
Thanks for all your guides! Great stuff you've done. Shame I've got a MK2 haha
Reactions: Lozzy15
Deleted member 103408
With regards to pre facelift setup this is the setup on my 2014 OBD11
Control unit 09 (BCM)
Long Coding
And just to update you can find all the long coding details from your phone using OBD11
Or they are recorded here http://obdeleven.proboards.com/thread/3262/control-unit-setup
Lozzy15
Mods mods mods
571
377
Don1961
212
118
Cracking guide..... looking through OBDEleven..... under Control Unit 9, there's an Adaptation HW_Verbau which has an option for 'Insufficient washer fluid'. Don't know if setting this to 'installed' would do the same as VCDS, if you don't have access to VCDS.
EDIT: More for face lift cars, as I don't think you can do long coding on them
Reactions: Lozzy15
Lozzy15
Mods mods mods
571
377
Thanks for the input, that could certainly help people without access to VCDS.
