Don1961
216
123
Coventry, UK
I've had the following fitted for a while now, with no problems.....
https://www.ledperf.co.uk/pack-interior-full-led-pure-white-for-seat-leon-3-5f-p-3664.html
Now I'm driving when it's dark I've noticed the following.....
Initially I noticed the front two reading lights were staying lit, but very dim. I've fitted resistors, as per the instructions, and that has fixed it.
However, when I take my foot off the accelerator and brake, the front two reading lights start flickering. When I accelerate again they go out and everything is fine until I have to slow down/brake again.
Anyone had the same issue with LED interior lights or know how to fix it??
Sounds like you have a short circuit developing, try fitting the tungsten bulbs back in and see if it still happens with those.
Have a close look at the printed circuit board, look for white powder or sticky gunge where corrosion is tracking across the soldered points.
Reactions: Don1961
Thanks. I'll have a good look tonight.
The car's only a year old but I'll check it all out and maybe try a different LED bulb as well as the tungsten ones
Had a good look at board.... looks OK.
Swapped with tungsten bulbs and they work fine.
I think the issue was caused by how I'd fitted the resistors.... I've now soldered them and it seems a lot better. Though they still flicker a bit... so maybe my soldering isn't brilliant
