Yes lots of flat run off and a nice straight where you can get a bit of speed going.
Filled her up, dangle-free
Decided to reroute some cables for the dashcam and various chargers, went through the dash as there's plenty of space behind the little storage compartment. What a nightmare to remove that, only held in with 4 small clips but it does not budge.
I chuckle a little every time (which is often )
Sent from my CLT-L09 using Tapatalk
Yeah, my life will never be the same again. Funnily
Enough as I was filling up, the guy in front had a Karoq and I could see his fuel cap hanging down. From a distance it looked to be the same setup as ours, I was tempted to go and speak to him... but chickened out in the end.
I suppose that makes me a bad person
Reactions: Legojon
As ours, I was tempted to go and speak to him... but chickened out in the end.
"How's it hanging?" *Walks away*
Yep, you're defo going to hell for that ha ha! First thing I could think to do when I found it was to share my gem of wisdom with you lot and look how crazy it's sent most
Reactions: Stephenator280
No, it's from a Skoda specialist. It's for the manual (Says not for DSG) but perfectly fits the DSG straight out of the box with same fittings. I'd seen others who bought it for their DSG Leon so it wasn't a risk.
http://www.superskoda.com/Volkswage...ned-footrest-for-RHD-cars-MANUAL-TRANSMISSION
Nice one, thanks. I've got a 2019 Leon Cupra Lux as well so will fit just right.
Only reason its 'not for DSG' is that normally the DSG pedal is wider.
Inreality a manual dead pedal will fit a DSG car, but a DSG dead pedal wouldn't work for a manual car.
As it happens I'm getting a custom light up one for mine. I could get the larger DSG version of that, but I prefer the narrower manual one I have at the moment. Give me more room between the brake pedal and dead pedal if I needed to stretch my leg out fully on a long drive.
