ah cool, hopefully can make it then. Hoping to do a full clean inside and out on the car this weekend so will get some photos up.Nothing firm yet but there may be another Blackpool area meet in January.
Theres The rolling road meet in Manchester if your up for it?ah cool, hopefully can make it then. Hoping to do a full clean inside and out on the car this weekend so will get some photos up.
@Big T I am running everything in first and due to job job change i'm not doing the mileage I was so not sure how long it is going to take.I think he wants to run his engine in first after fitting the new big end bearings.
Thats good then
Nothing worst than hitting full boost in 3rd then seeing the oil light after having the work
Just sharing advice after my experience
leon mk1 cupra
@Legojon @Jimbobcook any recommendations on engine bay cleaners?
Pretty much this for me as wellIt's one of the things I still use Autoglym for... I use their engine / machine cleaner sprayed on and worked in. Then use a water spray bottle to rinse. Then a coat of vinyl n rubber to make it black n shiny.
Yes fairy liquid is the stuff you need but be warned you need to do this clean away from your house or you will end up with a black puddle of grease, oil and general grime on the driveway.
Use it daily. Great stuff.Get some autosmart G101, you can use it a different concentrations for different jobs including the engine bay.
It's just an APC, others are available but it's one I'd reccomended if you can get it.
Sent from my Redmi Note 7 using Tapatalk
How much was that lad?Picked this up for weekend, safe to say my paint work is abit rough and has probably been washed with gravel and sand all it's lifeView attachment 10599
