2010 facelift Seat Leon Cupra
Deleted member 103408
Nothing firm yet but there may be another Blackpool area meet in January.
I think he wants to run his engine in first after fitting the new big end bearings.
Reactions: Legojon
Moody95
Whoosh and your away
Sep 26, 2016
163
79
Hull
The start of cleaning
Reactions: Sharpy and Legojon
Kenan
194
73
Get some autosmart G101, you can use it a different concentrations for different jobs including the engine bay.
It's just an APC, others are available but it's one I'd reccomended if you can get it.
Sent from my Redmi Note 7 using Tapatalk
Legojon
I only wanted a remap
5,284
2,714
@Legojon @Jimbobcook any recommendations on engine bay cleaners?
It's one of the things I still use Autoglym for... I use their engine / machine cleaner sprayed on and worked in. Then use a water spray bottle to rinse. Then a coat of vinyl n rubber to make it black n shiny.
Jimbobcook
6,150
2,533
Pretty much this for me as well
Sharpy
Oct 2, 2018
957
486
The autoglym stuff is good but very strong, depending on how bad it is I’d start with a citrus degreaser and if that doesn’t work then go on to something stronger, or that’s what I’d do.
Moody95
Sep 26, 2016
163
79
Hull
It's not real bad but it's something I failed to do on the fr but as the cupra is going to be long-term I want to do it properly
Yes fairy liquid is the stuff you need but be warned you need to do this clean away from your house or you will end up with a black puddle of grease, oil and general grime on the driveway.
Reactions: Legojon
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
731
Leeds
Use it daily. Great stuff.
