Oct 9, 2019
I have an xenon headlight leon 2012 and looking into converting it to normal halogen as mine are trashed and not keen on paying the silly price for a new set.
Just wondering if anyone has done it?
What's wrong with your system?
Backcovers
Bulps
Ballast
Level sensor
U can get cheap aftermarket on Ali and yes it works :)
The rest u can get used OEM like the asf module.
And indeed cloudy headlight u can fix cheap
Verstuurd vanaf mijn SM-G930F met Tapatalk
Backcovers
Bulps
Ballast
Level sensor
ive got the fault code 01535 which is a drivers side motor, headlight does not move up and down when starting the car. I cant find the part anywhere new or 2nd hand, only option ive found is a new headlight which is £££.
If you've seen the part available could you post a link. Thanks in advance.
