Which bulbs did you buy? Do you get any errors?Hello, added LED's under foot wells.
Doors closes and LED dimms
Sent from my GM1903 using Tapatalk
Yes, Engine, transmission and lower mount kit... Exciting times!Engine mounts?
Sorry for the late reply, seems this thread got lost in my notifications some time ago.Thinking about ordering a screen protector for the 8" media screen, anyone has one and can comment?
Would probably go for a tempered glass one if so, has one on my phone and it is brilliant.
The copper PPF cars are using an improved version of the G12 now.I checked under the bonnet of my daughter's May 2019 Leon Cupra - and discovered "Mit Silikat" printed onto the engine coolant reservoir - that could become annoying in the future!
Does anyone know if VW Group ever intend to improve/change the G13 coolant additive so that these bags of silicate don't need to be fitted to new cars?
No its moved on from those as well.Yes but that is just G13, which my daughter's May19 Cupra has and Norberts later 19 Cupra has - in fact all new VW Group cars from maybe 2014ish onwards will have G13 with no sign of any changes having being made to that yet - as in the previous version of engine coolant conc started as G12 moved onto G12+ and then again moved onto G12++ before being replaced with G13.
Yep!So if I'm reading this right... it went G11, G12, G12+, G12++, G13, G12EVO?
It is!G12EVO is that the latest one
bonkers
Well considering they forgot to change the part number in the manual but did change it to say G12Evo, probably not.Bother!!!! Now the next time my daughter turns up here I'll need to check what coolant is quoted on the reservoir body - or will VW Group have managed to get that bit right?
Couple of weeks ago I posted about my dynamic indicators
Finally uploaded the brief vid
Nice, do you plan on doing this to the rear?
I intend to purchase the dynamic mirrors but wasn't sure if it looks odd without the back done too.
I don't think it matters that I only have the wing mirrors done, any other change would be silly money. They are quite bright and for £34 I didn't mind messing about either. My mate who has a 19 plate 290 thinks they work better on the older version as they only have the small indicator flash rather than the beam on the latest model.
Always best to keep original parts!View attachment 11834
Cupra R 2018 - Replaced the resonator to a VAG Sport pipe kit to night.
Can’t say there is any drone. I’m not so sensitive for drone, I just increase the volume on Beats Audio!
Resonator. I will store it…. Perhaps I change my mind.
/Peter
