Whats the boost guage holder you have? Looks really good.
Had a few ups and downs over the last few weeks with the K1 not driving it much due to a misfire on cylinder
the code i was getting
P0304 misfire cylinder 4
Coil pack 1-4 swapped
spark plug 1-4 swapped
still the same , the miss would disappear over 2k and whilst driving it felt fine only on idle would i feel it , mostly when stone cold though it sounded like a cammed 106 gti
so after doing research on forums regarding the code i have , nearly all pointed towards or ended up being an injector at fault .
parts ordered were:
pcv lower hose
pcv gasket
pcv upper hose
New injector
vac pump seal
genuine inlet gakset
genuine throttle body seal
First up was removing the inlet manifold + high pressure fuel pump , this is not a bad job but very fiddly when it comes to removing the throttle body charge pipe (especially when you forget your trolley jack and can barley get underneath )
[/url [url=https://www.flickr.com/photos/158705908@N03/]
Gave the throttle body a well needed blast with carb cleaner
the "little bugger" (injector) , seeing as the coil pack / spark plug didn't change the misfire i was 90% certain this will be the cause of the fault
Looking at the inlets + inlet plates both were already coked in gunky carbon deposits even though i had them cleaned 9 months ago , just goes to show how quickly these engines can coke up !
So after an evening doing the job all went back on with nearly no hiccups bar be snapping a brittle lower pcv hose , the fuel was primed few times then she fired back to life running brilliant no misfires or codes happy days :) .
Next up will be fitting the helix clutch kit and wellycooler setup before the cold dark nights close in
Reactions: Legojon
Reactions: Nicholas Ellis
Little update.
The intercooler is doing a great job at keeping the temps down making the car feel eager as ever no matter how warm it gets.
Rear tyre, especially the near side rear was rumbling like a knackered wheel bearing.
Turned out to be the rear shock absorbers being totally shot, so new
rear shocks
rear shock top mounts
cover+bump stops.
(drop links/arb bushes were sent back as not being needed)
[The surface rust will soo been sorted]
The car has 4 Yokohama advan sports fitted now, for the price I cant complain. But i will soon be getting Goodyear ef1 super sports
Weekly washes being winter
[url=https://flic.kr/p/2k2FnhX]
I dont think i will ever go down the forge route haha fair play if you do legojon .
flikr is shocking for bluring things out i wish i had photoshop still to blur things neatly .
Untitled by Ashley Hanson, on Flickr
going back to the thermostat id highly recommend taking the alternator out it makes it so much easier gives you loads more room to work with
that same weekend i replaced the cat back part of the exhaust for a miltek system non res
the miltek systems are really nice but do check if buying second hand for rust and seized adjuster nuts 3 out of 8 were stuck on mine preventing me to adjust the system fitment properly .the sound though just for a catback system was actually pretty loud
I agree on the sound I bought my stock Cupra last year on an 08 plate and had done 47k fitted a catback Miltek and love the sound. Car looks sweet.
Cheers @scotty1310 :cool:
So a fair bit extra done to the K1 over the last few weeks
Forge motorsports screen wash tube/cap, a nice well made piece of kit that is also the most over kill thing on this planet ever.
Next up was a bulk purchase of genuine bits,
Rear drop links
Rear top mounts
Front drop links
Rocker cover gasket (spare)
Rear brake caliper hardlines
Oil turbo feed pipe
Boost pipe seal
Oil filter drain tool
After realizing the passenger side rear caliper has finally given up the ghost and sticking after nearly 12 years of service, I decided to replace it.
**limited edition silver spec till I get it painted**
Custom front and rear braided brake lines made by APB motorsport
Now the car is at the power I am happy with..... for the moment
H&R coilovers fitted recently but no pictures unfortunately
Handling upgrades
Powerflex black series bushes for
Upper control arms
Lower spring mount arms
Trailing arms
Also good condition bottom arms + trailing arms ready for polybushing in future.
Whiteline rear ARB (makes a big difference on these cars)
After accumulating all of these bits and bobs over a few weeks they all went on in a weekend give or take.
Rear subframe dropped, it wasn't in the best condition nor the worst I have seen so for now it was cleaned up and fitted with a C/M dead set rear kit including new subframe bolts x4
Untitled
3 out of the 4 eccentric bolts came out after a half hour of little fuss so I got very lucky.
The difference in weight of the standard anti roll bar is pretty crazy, almost feels the that of a broom handle were as the Whiteline is 5 times as heavy and thicker
One thing I also noticed was with the Oem trailing arms rubber bushes being a lot stronger density than the Febi ones I was going to use for the time being.
After realizing this the old oem ones went back on.
Subframe on
I'm going to aim at getting the underside completely cleaned and sealed in the next coming months now the days are getting longer and warmer.
A trip to AKS tuning for a fast road setup next week.
Cutting it fine the day before going to AKS
two bolts needed replacing due to the old ones looking worse for wear
Two of the rear arms getting poly bushed
Then the K1 was dropped off for the full alignment at AKS tuning, the guys there are superb keeping in contacted with me throughout the day making sure I knew what was going on with the car.
Now the suspension is properly set up the difference is night and day, turn in speed is very confidence inspiring constantly pushing you to take the corner faster every time.
Highly recommend getting this done, suspension isn't the cheapest mods but bang for buck you cant go wrong.
Update guys !
Decided a nice set of wheels were well overdue
Next mod will have to be a clutch to handle the 391ft-lb of torque also a suspension refresh
Tyres are federal 595 rs-R
All I can say is wow... I hope my K1 will look half as good as this one day. Mega example @ash_89
Reactions: ash_89
Haven't updated this thread for months...
Since having the wheel alignment done I took the K1 for its first track day!
Cadwell Park.
The track day was an absolute blast, with the K1 flying along on the straights and twisty's.
Moving on to the last few months I thought it was time to tackle a few preventative measures.
This included
-Painting the Sill front parts (where they meet the bottom of the wing) - This was done by a bodyshop
Untitled
After the paint was sorted I decided to do the cambelt as this was coming up to being due soon.
The job isn't too hard on these engines, just the main engine bracket being the biggest pain in the a**e.
All genuine parts used including genuine G12 Evo coolant
All on and timed up, checked twice before putting it all back together.
Fresh Coolant
All done
After doing this I noticed the brake booster pipe had split (due to the hose clamp pinching) so I purchased a new hose and a genuine clamp.
Also a new dipstick, even though it was a revised part it had still shown signs of wear, even cracking where the old part used to. I must check my oil too often :ROFLMAO:....
Thanks for looking guys, more track action soon once the weather clears up. [B)]
Reactions: thatslowk1
Cheers bro, fitting the mintex 1155 pads and new discs next
Then track rod ends and ball joints to freshen up the front end.
Oh and a set of decent track tyres, the list is never ending haha
