Replace MK3.5 LED footwell lights
Kirky
Copper Cupra Advocate
Apr 10, 2019
1,042
497
Does anyone know where I can get a red version of the interior footwell LED light that's compatible with the CAN bus?
This is what I have fitted.
Damo H
4,714
2,809
Car Length In Front
I bought mine off of eBay. But as they were so bright I ended up using some red filter to slide in to dim them. They’ve got 18 LEDs in...
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/253330816587
I know you can dim them in settings, but I liked my other interior lights at the 50% setting (the cubby hole under the air con settings is set by the same level as the footwell lights.
I’d previously tried the red sharpie but it just looked pink.
Kirky
Apr 10, 2019
1,042
497
Thanks for this. I will try find some with less than 18 LEDs. I'm not sure I have a light in the cubby hole you talk about as I was going to buy a USB led light for in there. I'll check that out before I buy as if I don't then the brightness doesn't matter as I can just set in settings without effecting other lights.
I found out since joining this forum there are a lot of things I hadn't noticed in the car or about the car. Turns out I'm not the most observant :happy:
Damo H
4,714
2,809
Car Length In Front
If you have the facelift you will. It’s just a small LED, if you’re not bothered by it, (or don’t have one in the updated Copra) then the above ones are fine on the lowest setting.
I should mention I used the same gel to turn my cubby hole light red.
Kirky
Apr 10, 2019
1,042
497
I got excited as found some on Amazon with prime postage for £11.99. Then I saw only blue was available :cry:
DOMINIC SELLY
lcupra300
Mar 30, 2019
61
44
Kidderminster
Has anyone got these but multi colour? I got some blue ones to replace the white but when changing the door lights it doesn’t match and can be rather painful on the eyes
Don1961
212
118
I have a Facelift and didn't have the cubby hole light....
so I fitted two of these.....
https://www.amazon.co.uk/gp/product/B0832L6JBB/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
and put the other three above the rear USBs in the centre console. All wired into the footwell lights
