Great idea but I want brighter ones. The OEM LEDs are a bit naff, even at 100%. So looks like I have to spend some money.Red sharpie the lens or get some red tint film
I bought mine off of eBay. But as they were so bright I ended up using some red filter to slide in to dim them. They’ve got 18 LEDs in...Does anyone know where I can get a red version of the interior footwell LED light that's compatible with the CAN bus?
This is what I have fitted.
Thanks for this. I will try find some with less than 18 LEDs. I'm not sure I have a light in the cubby hole you talk about as I was going to buy a USB led light for in there. I'll check that out before I buy as if I don't then the brightness doesn't matter as I can just set in settings without effecting other lights.I bought mine off of eBay. But as they were so bright I ended up using some red filter to slide in to dim them. They’ve got 18 LEDs in...
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/253330816587
I know you can dim them in settings, but I liked my other interior lights at the 50% setting (the cubby hole under the air con settings is set by the same level as the footwell lights.
I’d previously tried the red sharpie but it just looked pink.
If you have the facelift you will. It’s just a small LED, if you’re not bothered by it, (or don’t have one in the updated Copra) then the above ones are fine on the lowest setting.Thanks for this. I will try find some with less than 18 LEDs. I'm not sure I have a light in the cubby hole you talk about as I was going to buy a USB led light for in there. I'll check that out before I buy as if I don't then the brightness doesn't matter as I can just set in settings without effecting other lights.
I found out since joining this forum there are a lot of things I hadn't noticed in the car or about the car. Turns out I'm not the most observant
I got excited as found some on Amazon with prime postage for £11.99. Then I saw only blue was availableIf you have the facelift you will. It’s just a small LED, if you’re not bothered by it, (or don’t have one in the updated Copra) then the above ones are fine on the lowest setting.
I should mention I used the same gel to turn my cubby hole light red.
https://www.amazon.co.uk/2x-LED-Mod...5?keywords=smd+footwell&qid=1577099852&sr=8-5I got excited as found some on Amazon with prime postage for £11.99. Then I saw only blue was available
Yeah these are the ones I think I'll get, thanks.https://www.amazon.co.uk/2x-LED-Mod...5?keywords=smd+footwell&qid=1577099852&sr=8-5
How about these? Can't get them before Xmas, but not far off.
This just go in to replace where the oem bulb is?https://www.ebay.co.uk/itm/2x-NEW-F...VW-AUDI-SKODA-Seat-units-canbus-/292230271382
I got a pair of these in red
I have a Facelift and didn't have the cubby hole light....If you have the facelift you will. It’s just a small LED, if you’re not bothered by it, (or don’t have one in the updated Copra) then the above ones are fine on the lowest setting.
