Intermittent EPC light
Feb 11, 2020
8
Hi all, the EPC light is coming on every day on my 2.0fsi mk2, I've scanned it but not getting any fault codes? Though I can clear the light it will then return at some point. Seems to be no pattern to it coming back, drives perfectly no stuttering or limp mode etc all lights are working I'm out of ideas. The only thing I can think of is the aftermarket pioneer stereo but I don't know if that could have anything to do with it. Any ideas? Light was on since day one of ownership.
Thanks in advance
Sent from my LYA-L09 using Tapatalk
Legojon
I only wanted a remap
5,316
2,748
What are you scanning it with? Might need vcds to show the code.
Feb 11, 2020
8
Its just an obd scanner borrowed from a friend, diagnose it, it says zero fault codes and nothing stored. Only a cheap thing so I could need a newer/better model?
Feb 11, 2020
8
Vcds is the vag com thing yes? Do I need to hook it up to a laptop for that?
Legojon
5,316
2,748
Probably a generic scanner .... I'd use a VAG specific one.
