Yeah it seems okay looking at it looks a right pig to get to one of the sensors, probably going to be a weekend jobNo way. I'm sure they'll send out another loom if that's the case. Is the control box ok?
I had a go at fitting it got B and C plugs connected, managed to get A plug off but the Racechip connector would not attach, physical size is correct but there is a plastic tab within the plug in the wrong position so would not plug together.Keep going Bigjase88 , wiring looks very similar to the DTUK box I did a couple of years ago on a Astra 1.4t.
A bit daunting to start with but once done you should feel a difference.
After a few times of taking it off (for servicing etc) and then re installing it's easy.
Yeah you don’t actually need to remove that you can skip that step, is a little tricky with it in the way however.Ahh is that what that silver circular thing is? A charcoal filter? You've got good eyes to spot that wire damage mate. It looks like it's well built though with mouldings to protect the loom where is branches.
Negative, probably still on google translateAny reply from our German friends at Race Chip?
I deleted all my social media about 6 months back as I was spending too much time on them, now I spend too much time on car forumsHaha. I was messaging them through Facebook messenger on their official page and replies were generally within a day. I'm having an oil leak looked at next week (at the transmission join with the engine) do will get mine ordered after that as it doesn't look like a quick job to fit or remove. I'm impressed with how it looks though.
No reply yet?I now realise i was being stupid and had located the wrong sensor.
there are 3 sensors in the exact same location and as its down a bit in the bay they are hard to see and locate and the instructions / pictures are not very clear.
i would fit the box now but i wouldn’t want to chance it not with the wire the way it is, 2 or 3 strands of the cable core are broken and i wouldn’t like to chance it and have an electrical fire,
so looks as if all i need is a new loom and good to go.
if they don’t want the original back i may splice the cable and solder it back together tomorrow at work which will get it up and going in the meantime
Yeah obviously it’s just been a quick test with it on, it is much much faster at silly speeds 70mph+Sod it. I'm going to give it a shot and get one ordered. By the time it gets here my car will car will have been seen by SEAT. I'll PM you my email so we can share a beer through the referral fee.
I can't see the more expensive boxes being drastically better really. Cheers Jase. Good write up.
