Johny
52
Hi guys, im about to remove the front panel including radiator, the entire front end as one piece basically, the bumper, wings, its all out already. What im wondering is which hoses i need to disconnect and also where are all the screws i need to remove.
And regarding the downpipe, what size are the bolts on the connection to the turbo? Thanks
Odesláno z mého SM-N960F pomocí Tapatalk
Two water pipes from the radiator
Air con pipe from bottom off the radiator and air con pipe from the air con pump the back one
Both plugs for the fans
Remove bonnet catch to remove the cable release
Bonnet catch wire plug
Pull the bonnet release cable out off the front panel
The four 10 mm bolts from the top off the front panel 2 either side by the wings
Top left 13mm and bottom right 13 mm bolt from each leg where the crash bar is
I think that’s everything I have just done this to a car that I’m breaking
Reactions: Johny
Sorry for the late response mate, I thought I replied. Thanks for the help, it was pretty easy.
