Speaker size
Charliessmith
494
51
yeah just a bit! I currently only have the Focal mids and tweeters and use a different 8" for the doors, a pair of 8" Utopia woofers are £1300!!
Thats well to expensive for me, I've been looking at the focals k2 and the ISU200 what do you think?
Sent from my SM-N770F using Tapatalk
Charliessmith
494
51
JL Audio are another recommended speaker brand..
What cupra you got because I don't have the different floor levels like you. I used to have that in my VW Polo but I don't have it in my cupra 290 mk3
Charliessmith
494
51
The only info i can find ATM is from a Seat price list, it says 135watt 6 channel amplifier 10 speakers including sub.
Do you know you the fitting depth you can get away with?
I want to put JL Audio C5 650 in the front and back but i don't know if they are to deep.
Marko70
107
46
depth will also be limited by the width of the magnet as there is a bracket with bolt holding the bottom of the window channel to it, I made a spacer of approx 36mm so the speaker almost fits flush with door card.
Charliessmith
494
51
Will I be able to fit JL Audio C5 650?
Is the front and rear 2 way or 3 way component?
Marko70
107
46
"should" be OK but without actually trying them I wouldn't say yes!
yes, 2way front and rear is stock.
Charliessmith
494
51
Cool, can I get a bracket to put a 6 and a half rather than an 8 inch?
Is stock a 2 way component system in the front and rear?
Charliessmith
494
51
If I get the JL Audio C5 650 for front and back can I use the stock wires or will I need to re run all the wires for the speakers?
