FOX1429
100
15
Wales
Hi,
Recently purchased Leon Cupra 300
Loving it.
I’ve done some research on Here the above but I’m a real technophobe so please be kind!
I’m interested in purchasing to change a few things in particular turning down/off sound actuator needle sweep etc
Ive done eBay search but not sure what I actually need to buy as there’s loads of versions/options.
Would someone be kind enough to answer some questions:
1. Link to actual carista I need to buy / one you have
2. Is it just a case of loading app to iPhone, plugging it into OBD then cracking on?
3. Are the menu’s easy to navigate to make the changes etc
4. I’ve read about subscriptions/paying more to change settings? What’s this about/how does it work
sorry for the numb questions but never done it before and don’t want to pay out if it’s something a novice can’t/shouldn’t be messing with.
hope that makes sense.
thanks in advance
Hi,
Loving it.
thanks in advance
Good morning, I'll try to answer your questions, as I recently bought it for my 2015 ibiza.
1. You can buy it from here : https://www.amazon.co.uk/dp/B00YVHGTBM/?tag=carista-21
2. There is an android and an iPhone app version, so it's a simple plug the device to your obd and change what you want through the phone.
3. It has a pretty simple interface. So everything you change is pretty straightforward.
4. It has various subscription fees ( week,month, year) , but when you buy the carista obd2 device, you get one month full operational, free of charge. (That's what I have done...)
You'll find more here.....> https://caristaapp.com/ , if you want to check if your car is compatible with full customization. ( which i think it will be...)
Hope it helps
Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
Reactions: redtee34
Hope it helps
thanks mate I really appreciate the reply I’ll have a look and check compatibility
Once subscription ends can it still do basic fault scans etc? I have been looking at the basic obdeleven doesn't require any subscription, but then they have a pro range you need credits for.
All new to this also.
You get 5 free credits everyday for watching adds. Takes 2mins :)
Reactions: Sjdickso
I'm not sure, but I think that when subscription ends, you only have access to very basic staff, like scanning but not able to find exact code of fault, or unable to reset such errors
