Oh I also managed to curb my rear wheel today too. In 13 years of driving literally the first wheel.i curb is a diamond cut sub 8 wheel
Sent from my Pixel 2 XL using Tapatalk
Depending on how deep the curb mark is, you might be able to get it resurfaced. Only downside to diamond cut is how fast they corrode.
It's not too bad. I'm just ****** off that I did it.
I'm gonna just gonna stick some lacquer in it to try and seal it up. I've never really liked the diamond cut, so will just let it get bad then refurb the set.
Lowered the car. Now sitting on Eibach pro kit springs.
Just to add,
I had a bit of work done.
Eibach ProKit now fitted
Front Strutbrace fitted
Superpro Alloy arms fitted
RS3 brake ducts attaches to arms
Front and rear brake pads - DS2500
RBF600 fluid flush
Full service.
Reactions: Walone and queen
Finally got the reiger rear diffuser attached and the new silencer and tips added today.
Reactions: Hag
Didn’t do anything specific.
Fitted an 8” screen to the pfl.
Looks great (great album that btw!) How hard was it? Did you do it yourself or elsewhere? Any issues with component protection, size etc. All functionality working fine? Would appreciate any advice you can give, as I have the same car as you...
Forgot to get back to you.
Its quite straight forward. I will write it up on my build this week.
Why haven't you covered whole areas and you have put small pieces everywhere?
Based on what I've read on the forum, I understood that there's really no need to try to cover the whole area, as it would return the same result.
Also, I don't want to add too much weight to the car. I will be adding a foam-like material as a second layer anyway.
Today I wondered road the back of my FR for 20 minutes trying to find the whistling noise that seems to be coming from the boot/spoiler somewhere when the wind blows got in the boot a few times neighbours probably think I'm a nutter still no luck
Added some more tints today, to the rear deflectors, nothing major but looks much better in the flesh :)
in need of a much needed wash and detail before the winter months ?
