I do consider it money well spent. It's around £100 for someone to fit, so if you were able to source all the parts yourself, you could save a fortune. Some virtual cockpits for for less than £300 on eBay, and then the trim surround is around £40 brand new from SEAT. If you shop around, you could get the whole thing (parts and fitting) for less than £500.
Although £500 is still a lot of money, it's cheap for a VC conversion.
I genuinely expected double this figure at a minimum
I've not updated this thread for a while, so here goes!
Mods completed since the last update:
  • Remus Resonated Cat Back System with 4" Slash cut chrome tips
  • BAF Rear Brace
  • Diesel Geeks Stigma Quick Shifter kit
  • Virtual Cockpit upgrade
  • Funk Motorsport Turbo Blanket
  • RacingLine Upper Engine Mount
I've got the following items to go on soon too:
  • RacingLine Upper Transmission Mount
  • DO88 Charge Pipe Kit
  • DO88 Enlarged Muffler Delete
  • Fluidamp Crank Pulley + new belt
  • 4" Intake Hose and larger R600 filter
  • Wireless Apple CarPlay
  • Wireless Charging
The DO88 Charge Pipes will replace my Leyo ones, or at the very least, i'll create a mix and match solution out of the two kits.
Love the exhaust
