rear wiper fix leon 2016
Eddiedunn12
my 2016 leon fr estate has lost its power to the rear wiper, is there an easy fix to this please? my boot open sensor came on, after a quick search i noticed this would be my rear wiper.
any help would be apprecited.
Walone
1,559
429
Near Heathrow
The wiper won't work if the boot is open, you need to find the cause of the boot showing open. I did have this once and had to slam the lid shut a couple of times and it's been ok since.
Eddiedunn12
where or how can i find the boot sensor? or will it be a fuse somewhere?
thanks
Walone
1,559
429
Near Heathrow
thanks
I doubt if a fuse will be the culprit, the 'sensor' is probably part of the boot latch mechanism. With the boot lid fully shut pull down a rear seat back or release the luggage cover (ST) and look to see if the light in the boot is on all the time, I think it will go out automatically after a short time anyway as the electrics are 'put to sleep' to stop the battery discharging.
Reactions: Eddiedunn12
Eddiedunn12
The wipers are now working but the sensor is still an issue. I’ll check tomorrow on your tip and let you know if I find anything
thanks
Reactions: Walone
Eddiedunn12
Are you saying that the indicator on the dash is showing the boot is still open, but the wiper is now working?
Yes, wipers weren’t working originally, now they are.
Now it’s just the boot sensor still says open!!
I’ve read a few things on here to say take off the latch and clean it, so going to try that and also clean the rear washer pipes. Other than that I’m stuck!
many other suggestions?
Walone
1,559
429
Near Heathrow
It maybe that the 'error' is stored and will need clearing with OBDeleven or VCDS, but I've not heard of that happening. It's strange that the wiper is now working with the warning light on.
Eddiedunn12
I’ve took the boot apart this morning, sat with the engine on whilst sitting it and playing around with connections. Looks like it’s this connection which is the boot lock itself! Going to order a new boot lock, hopefully that’s fixed it. Took all the lock off and cleaned it too!
Reactions: Walone
